Techs ball joint separate!
07MAC-SL00200 theres the part number to Honda Genuine ball joint remover
i know i dont need this tool but i like to try to make things clean as possible 1. Where can i find this tool? 2. How much? (Honda charges $210 <before employee discount>) 3. I've heard you can use a 6" gear puller? where can i get this or another alternate tool? Any help would be appreciated thank you guys. |
Re: Techs ball joint separate! (HondAcura)
the balljoint puller from autozone works great for me, not the fork; but the C one
Yeah, the pitman works great and it's only $10
If you use the pitman tool though be sure that as you're tightening the vice that it's not crushing the threaded end of the ball joint stud. |
Re: (DXkid888)
Thanks alot guys!!!
http://toyota.spx.com/detail.aspx?id=710&g=22
It's a Toyota tool but this is my favourite ball joint puller... I love using this thing!! Protip.. what ever puller you use, you need to thread on a normal nut (not the castle nut) onto the stud to prevent the stud from bending or collasping the cotter pin holes. |
| All times are GMT -8. The time now is 06:39 PM. |
