SWITCH PANNEL TO HONDATA?
I HAVE A 6 SWITCH PANEL THAT I WANT TO WIRE UP TO MY HONDATA, DOES ANYONE HAVE A SCHMATIC DRAWING ON WHAT WIRES TO CONNECT TO THE HONDATA? NEED HELP?:thud:
Re: SWITCH PANNEL TO HONDATA?
Sorry for my ignorance but what do you mean by a switch pannel.
its a painless 6-switch panel. *push button start, and 5 toggle switch acc. switches- for fuel pump, fan, etc.
describe the set up in a little more detail. you have a car with a hondata ECU and you have a switch panel that you want to use in it (i hope it's a track car... switch panels make it easy to hotwire.)
yes its a drag car. i have a hondata s300 with stock integra wire harness, and a painless 6-switch panel. my question is,does anyone have a drawing or something showing how to wire in this switch panel?
oh cool.
i don't have a schematic or drawing but i would suggest studying the wiring diagram in your repair manual and substituting the switch panel components witht the corresponding component in the diagram. you may be looking at replacing several switches or relays with one... but getting the full diagram in front of you should help. |
ok thanks
| All times are GMT -8. The time now is 10:21 PM. |
