Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   stripped engine mount threads (https://honda-tech.com/forums/tech-misc-15/stripped-engine-mount-threads-2849737/)
raverx3m Oct 15, 2010 05:51 PM
stripped engine mount threads helicoil or bigger bolts?
i ve just notticed that my driver side engine mount bolts are stripped.
only 2 top ones not the bottom bolt.
went to napa to see how much it cost to get helicoil kit its 67 bucks without the drill bit.
kinda expensive at the moment for me.
is there an alternative like rethreading it for bigger bolt instead?
and what parts/bolts/tools are needed.
is there a bolt available from honda in a next size up? from a different engine maybe?
lsd96teg Oct 16, 2010 03:36 PM
Re: stripped engine mount threads
I honestly did this, I bought the kit used the two springs and returned it. They didnt notice
2k.civic.si Oct 16, 2010 09:29 PM
drill/tap for bigger bolt.
v8killaz Oct 16, 2010 09:45 PM
yep
boostedteg1203 Oct 16, 2010 11:03 PM
Just use the Helicoil kit. I got one from O'Reilly auto parts for $42. It you got to a larger bolt you'll have to drill out the bracket. And the heads on the new bolts may hit the upper portion of the bracket. I actually went to a M10-1.50 instead of the normal M10-1.25. The 1.50 uses a larger bit so you are sure to get all the old thread material out.
itslogz Oct 17, 2010 01:08 AM
With something of that statute, i would opt to not use a helicoil, MAYBE a timesert. I would probably honestly just drill the mount out a bit, then tap it for the next size up and it would be good as new for nearly free.
fcm Oct 17, 2010 06:21 AM
Drill and re-tap for bigger bolt, you can get the bolts at any "fastener" shop. 94
raverx3m Oct 17, 2010 04:11 PM
went to local NAPA and got the bigger bolt tap washers and drill bit. cost me about 20 bucks compared to 67 dollars napa wanted for helicoil. and it seemed much easier as well.
btw how would 2 top bolts strip and not the bottom one? bent frame because of an accident?
raverx3m Oct 18, 2010 08:36 AM
so i thought :)
went and got a cobalt drill bit from sears that said to be for hard metals
put it in my drill and try to make a hole bigger
but theres not even a scratch on the engine mount and the drillbit is already dull.
what kind of drillbit do i need to get?
fcm Oct 18, 2010 11:15 AM
A cobalt bit should work, but you may need a drill press, slower drill speed and "drilling oil".
http://www.ehow.com/about_4703523_dr...ned-steel.html 94
raverx3m Oct 19, 2010 11:50 AM
So we tried drill press. Didnt even scratch a surface. Drill bit is toast. Wtf is this mount made of? Adamantium? I tried to use a file that thing just slides on the sirface.
raverx3m Oct 19, 2010 04:43 PM
update.
engine mount 0
drill bits -4
i tried cobalt bit
machine shop tried drill press
another machine shop tried drill press with carbide bits one got chewed up
another cut it half way and got chewed up as well.
so i dont know how any of you guys drilled thru the engine mount must been using some crazy drill bits.
jdmrexx402 Jul 17, 2011 01:09 PM
Originally Posted by raverx3m (Post 43814448)
update.
engine mount 0
drill bits -4
i tried cobalt bit
hate to bring back from the dead but im stuck with the same thing tried drilling threw but no luck. anyone know what to do
hybrid24 Jul 17, 2011 08:16 PM
me 2 ^ sry but .... i got the same problem one broken bolt would like to know what people have done havent tried anything yet
my dad said he has this bit might be called "easy out" dont hold it to me but it drills into the bolt center and backs it out of the hole any one used one of these?
Organization Jul 18, 2011 12:08 PM
if they used a real carbide bit and it got chewed up on a drill press then i dont know what to tell you
try a titanium drill bit in two steps one just a bit bigger than the hole then one the size hole you are tring to enlarge it to use a slow speed with lots of pressure and hydraulic oil, i had to drill tru a honda accord rotor bolt and did not have a titanium bit and let me tell you never again went to home depot and made my life easier and got a titanium bit
Organization Jul 18, 2011 12:10 PM
it works when done properly just grind or file the broken bolt as flat as possible and center it up as best as posible
raverx3m Jul 18, 2011 01:45 PM
I ended up using coil and same size bolt.
Although i am pleased to know that my entine mount will not break lol.
Rickcrx Jul 20, 2011 04:56 PM
2 bolts out 3 snapped on my B18b ek hatch and that was the worst thing ever for me. First i pulled the driver side mount the lift the motor a bit to get in to the mount holes on the block. I used a carbide 1/8 drill bit and got the hole goin after 3 drills i had a deep enough hole for me to put a easy out and crank the motherfu****. The other one i had to helicoil. If u retap it for a defferent size bolt make sure it goes tru the mount first lol. Heilcoil are very strong and maybe stronger then just an alum thrd.
