Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   sohc to dohc (https://honda-tech.com/forums/tech-misc-15/sohc-dohc-244288/)
poz15 Aug 1, 2002 07:57 PM
sohc to dohc
my friend said that changing my 97 civic ex from a sohc to a dohc would add about 25-30 hp is this true or just bs thanks
dirtySOHC's Aug 1, 2002 08:02 PM
Re: sohc to dohc (poz15)
you talkin about a swap.......it depends on wat motor.
damn man........read the board. there are hybrid gods in here.....and tons of information.
Koori Aug 1, 2002 11:27 PM
Re: sohc to dohc (dirtySOHC's)
Hmm.. Well, it sounds to me that you're doing a direct sohc to dohc conversion on your stock D16Y8. Umm, you better put your hip boots on cuz someone is waist high in shit talking. As for a b series swap.. A B16A (99-00 Si) would put you about 30hp higher at the crank. The B18's (A, B, C5) are the shit. You could be pushing anywhere from 160 to 180hp range..
poison Aug 1, 2002 11:37 PM
Re: sohc to dohc (Hadji)
Well said http://images.zeroforum.com/smile/emthup.gif
That's a pretty broad statement, but if he's talking about a motor swap, then yes, as for putting dohc on a sohc block, unless it's a ZC -- not going to happen.
HTH http://images.zeroforum.com/smile/emthup.gif
.BULLET. Aug 2, 2002 01:49 AM
http://images.zeroforum.com/smile/emthup.gif have a beer http://images.zeroforum.com/smile/embeer.gif well said...im getting my swap also (b16b)...cant go wrong with a b series motor...i think u should just get a jdm gsr...my cousin has that and i got spanked in 1st gear when i raced him...to get my point across..... if u want high end, get a jdm gsr...if u want ur car quick at the start, get a b16a2...the gsr kinda lags but will spank u in high end...good luck http://images.zeroforum.com/smile/embeer.gif
Civic1992DX Aug 2, 2002 05:25 AM
Re: sohc to dohc (PEN15teamJDM)
GSR engine will ALWAYS spank B16 (considering them in the same type of car)! More torque = more pull off the line. Even my B18B1 pulls harder than B16 off the line.
mugenracer Aug 2, 2002 05:03 PM
Re: sohc to dohc (Civic1992DX)
so so true http://images.zeroforum.com/smile/emthup.gif
slomofo Aug 2, 2002 08:19 PM
Wiring a B18C1 into a civic is a bit difficult though.
Civic1992DX Aug 2, 2002 08:33 PM
Re: sohc to dohc (slomofo)
slowmofo, you made me laugh! JDM 3-1 header, Geo Metro type R http://images.zeroforum.com/smile/emsmile.gif
I had 1.5 bottles of wine & it's FUNNY!!!! Hahaha!!!!
Peace...
Yuri K
