Shitty Compression Results, options?
so, before the tuning session yesterday, we did a compression test on my car-- setup is:
83mm Benson Sleeves 83mm 9:1 CP pistons Crower Rods LS Crank GSR head Supertech Valvetrain My compression results were: Cyl 1 Cyl 2 Cyl 3 Cyl 4 190ish 190ish 160ish 200ish Now my tuners tester reads a little on the high side he said, but what I'm worried about is cyl 3. Couple theories I have (before doing a leak down): The piston to wall clearance is a litle on the big side (slapping before warmed up), and the motor had a chance to cool down before we did the comp check, so maybe the piston hadn't had a chance to seal the cylinder yet. Theory two: Just did a valve adjustment about 5 days before, maybe i did something in number three that would allow the valves to stay open just enough to lose compression. I will be doing a leak down within the next week-- just trying to pick your brains before. |
| All times are GMT -8. The time now is 05:59 AM. |
