selecting bearings...
ok i'm trying to figure out what kind of bearing i'm suppose to use.I'm using aftermarket rods so i can't go from the numbers on my stock rods.i read somewhere that when you are using aftermarket rods green bearings should be ordered.For the mains i'm just going with the colors that i'm suppose to use according to the letters/numbers on the block/crank.
this is on an f22a6. any comments/suggestion apreciated. ILBB |
Re: selecting bearings... (ilikebigbutts)
Your best bet for price will be ACL's (if they make them for that) + any OEM bearings if you have one out of spec. 2nd would be an OEM set according to your codes, but with an extra + and - size set from an OEM internet supplier. My local stealership charges full 'retail' for them, but has to special order them, taking the same amout of time as the internet places usually do.
Stay away from other brands, they tend to vary quite a bit for clearances. |
| All times are GMT -8. The time now is 11:59 PM. |
