Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   screwed over by stock cat... (https://honda-tech.com/forums/tech-misc-15/screwed-over-stock-cat-757751/)
brainiak Feb 5, 2004 02:22 PM
i just dropped in a 97 b18c spec-r on saturday..
i have been driving with just open header since today..
i went to this muffler shop and asked them to do my piping but they said i needed a cat.. i was in a rush so picked up my stock cat..
they installed the cat and 2.25" piping..
i drove the car off and i noticed it became significantly slower but much quieter..
how can i fix this? should i just do no cat at all? or what about a hi-flo catco cat?
thanks in advance. https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif
brainiak Feb 5, 2004 04:15 PM
Re: screwed over by stock cat... (brainiak)
to the top.
thank you. https://honda-tech.com/forums/images/smilies/emthup.gif
Kendall Feb 5, 2004 04:18 PM
Running any exhaust system will feel slow when compared to running an open header. But a high flow cat will help. For the B18C-R motor you will probably want to think about upgrading to a 2.5" cat and exhaust anyway.
brainiak Feb 5, 2004 06:12 PM
Re: (Kendall)
thanks. https://honda-tech.com/forums/images/smilies/emthup.gif
Jimmy Feb 5, 2004 06:29 PM
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Running any exhaust system will feel slow when compared to running an open header. But a high flow cat will help. For the B18C-R motor you will probably want to think about upgrading to a 2.5" cat and exhaust anyway.</TD></TR></TABLE>
*but*
I dont think this is the case..I felt the same with my cat Installed
I want the power of no cat but when i put a test pipe on it sounds like shit and has its power back so i took the loss and kept my car
but in your case its your cat so get a test pipe depending on where you are located.
brainiak Feb 6, 2004 04:45 PM
to the top again. https://honda-tech.com/forums/images...es/emsmile.gif
Kendall Feb 6, 2004 06:05 PM
I wouldn't recommend a test pipe as a good high flow cat won't cost you hardly any power anyway. I still think your best bet is a 2.5" cat and exhaust.
