Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Scrape on H22 block (https://honda-tech.com/forums/tech-misc-15/scrape-h22-block-1129172/)
93H22ACX Jan 27, 2005 03:57 AM
Scrape on H22 block
I just picked up a H22A4 block for the crank. Got it really cheap.....but i would like to know if the block is still reuseable. It has two deep cuts on the block. Here is the pictures.....let me know what you guys think...yes reusable or no not reusable...
http://www.imagestation.com/picture/...b/f551d91c.jpg
http://www.imagestation.com/picture/...7/f551d91a.jpg
http://www.imagestation.com/picture/...f/f551d917.jpg
http://www.imagestation.com/picture/...a/f551d912.jpg
tgreaves Jan 27, 2005 06:06 AM
Re: Scrape on H22 block (93H22ACX)
How deep is the cut? Hard to tell from the pics but it kinda looks like a scratch on the surface..
93H22ACX Jan 27, 2005 06:24 AM
Re: Scrape on H22 block (tgreaves)
probably like .5-1mm deep
93H22ACX Jan 27, 2005 06:25 AM
lets say i want to use this block later on..can i fill it with something and use copper hg sprayer on the the hg to make a better seal?
tgreaves Jan 27, 2005 06:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">lets say i want to use this block later on..can i fill it with something and use copper hg sprayer on the the hg to make a better seal?</TD></TR></TABLE>
I would say you would be fine with using copper spray on that.. Only thing that scares me is that the crack might spread..
93H22ACX Jan 27, 2005 06:30 AM
thats true. its not a crack if it matters. its a cut or gouge
tgreaves Jan 27, 2005 06:40 AM
Not sure what to tell you.. I would take it to a machine shop and have them look at it.. Or you can get it sleeved..
93H22ACX Jan 27, 2005 06:43 AM
yeah... i think AEBS sleeves woul take care of it
tgreaves Jan 27, 2005 06:50 AM
Any sleeve would take care of it..
GDM Z28 Jan 27, 2005 07:00 AM
if its just on top take it to a machine shop and have them deck the block and see if it takes it out.
93H22ACX Jan 27, 2005 08:11 AM
Re: Scrape on H22 block (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">if its just on top take it to a machine shop and have them deck the block and see if it takes it out. </TD></TR></TABLE>
i thought about that but the machine shop might haev to take too much off where the piston might stick out of the hole.
GDM Z28 Jan 27, 2005 08:15 AM
i thought about that but the machine shop might haev to take too much off where the piston might stick out of the hole.</TD></TR></TABLE>
thats y u gotta bring it to the shop n see what they say.
mmuller Jan 27, 2005 08:32 AM
it looks like the block could be decked to get rid of those scatches no problem; but then again, it ''looks'' like...
93H22ACX Jan 27, 2005 09:07 AM
Re: Scrape on H22 block (mmuller)
thanks for the help guys.
