Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   removing my engine harness, I broke a sensor....what is it??? (https://honda-tech.com/forums/tech-misc-15/removing-my-engine-harness-i-broke-sensor-what-1442089/)
B16CRXT 11-22-2005 07:26 AM
Im removing my motor so I can build my bottom end, and while I Was removing the engine harness I couldnt get the wires off of this sensor and I ended up breaking it. I unscrewed the sensor and coolant started coming out so I put it back in. It is below teh vtec solenoid. Here are some pics.
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
TIA! https://honda-tech.com/forums/images/smilies/embeer.gif
eg crunkmonster 11-22-2005 07:41 AM
Re: removing my engine harness, I broke a sensor....what is it??? (B16CRXT)
tw switch, its like $25-30 at the dealer, u can get it off any honda head. I broke mine and justgot a new one since it was cheap
B16CRXT 11-22-2005 04:41 PM
Re: removing my engine harness, I broke a sensor....what is it??? (eg crunkmonster)
sorry, but I cant even think of what tw means....
eg crunkmonster 11-22-2005 04:43 PM
i think its the one your cluster reads for the temp, but not 100% positive
shamoo 11-22-2005 06:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">i think its the one your cluster reads for the temp, but not 100% positive</TD></TR></TABLE>
You are correct. It is called the Engine Coolant Temperature Sensor (ECT sensor). https://honda-tech.com/forums/images/smilies/emthup.gif
B16CRXT 11-22-2005 07:03 PM
where the hell is it in here?: http://www.hondaautomotivepart...EC%29
eg crunkmonster 11-22-2005 07:21 PM
Re: (B16CRXT)
its part number 37870-PJ7-003 and listed under "water pump/thermostat" slhonda.com is a better site to look for things, u can click the number on the pic and get the part number and name
B16CRXT 11-22-2005 07:53 PM
Re: (eg crunkmonster)
sweeeeet. thanks man https://honda-tech.com/forums/images/smilies/embeer.gif
tgreaves 11-23-2005 11:43 AM
Re: (B16CRXT)
Go to a junkyard and grab one off of any honda/acura.. They are all the same..
eda6 11-23-2005 12:04 PM
Re: removing my engine harness, I broke a sensor....what is it??? (shamoo)
actually the signal is sent to the cluster from the temp gage sending unit. It has a yel/grn wire with a female bullet connector on the end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">It is called the Engine Coolant Temperature Sensor (ECT sensor). https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Go to a junkyard and grab one off of any honda/acura.. They are all the same..</TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif
tgreaves 11-23-2005 12:49 PM
Re: removing my engine harness, I broke a sensor....what is it??? (eda6)
Also you can still drive with it like that for the time being, only thing is your temp gauge on your cluster isnt going to work..
B16CRXT 11-23-2005 06:58 PM
Re: removing my engine harness, I broke a sensor....what is it??? (tgreaves)
I see. I'll justyank one from a junk yard later on after the engine build is done. im not really worried about it right now, just was curious as to what it was...thanks for the help guys! https://honda-tech.com/forums/images/smilies/emthup.gif
Py7h0n 11-23-2005 09:51 PM
Not only that, the ECU uses it to calibrate cold fuel enrichment.
