Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Radiator and VTEC ques?????????????? (https://honda-tech.com/forums/tech-misc-15/radiator-vtec-ques-492925/)
DeDonDeRosa May 1, 2003 02:05 PM
if u install a lager rad like a C&R will it affect VTEC by the normal operation temp because this rad will make your car run cooler and i wasnt sure if this would affect vtec working because it would run cooler??
raene May 1, 2003 02:13 PM
Re: Radiator and VTEC ques?????????????? (DeDonDeRosa)
Quick answer: No.
Reason: The thermostat will close if the coolant temp gets too cold, so the engine will stay at roughly the same temp.
HTH!
