Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Quick question about compression! (https://honda-tech.com/forums/tech-misc-15/quick-question-about-compression-716295/)
^jefs0ng Dec 27, 2003 12:19 AM
Okay so bad valves has caused some horrible compression #s. So low that one cylinder isn't even firing. I must admit my car still hauls ass for a 3 cylinder. ANYWAY I came across some oem b16a2 valves. Now my question is, should I be getting the valve springs and retainers? Is there any chance mine would be bad from my valves? I mean it's not that much of a deal since it's all fairly cheap and I can go check them out.. input please? I'm just jobless and poor so I'd like to save every penny possible. But if it's "safer" or recomended to replace the whole valvetrain I will.. thanks!
fulldragcrx Dec 27, 2003 06:58 AM
Re: Quick question about compression! (.jefs0ng)
What testing have you done to make sure its your valves.
if it is why did the valves go bad?
what engine are we talking about ?
LudeyKrus Dec 27, 2003 07:51 AM
Yes, how did you figure it was the valves?
If it's FOR SURE the valves, then no, you just replace the valves. Unless you're building this for some high revving and it's a high mileage head, there should be no prob w/ the springs and retainers.
^jefs0ng Dec 27, 2003 11:08 AM
Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Yes, how did you figure it was the valves?
If it's FOR SURE the valves, then no, you just replace the valves. Unless you're building this for some high revving and it's a high mileage head, there should be no prob w/ the springs and retainers.</TD></TR></TABLE>
awesome I know it's the valves, cause we did the whole oil thing to check if it was my rings.
smokey2.0 Dec 27, 2003 11:34 AM
Re: (.jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">
awesome I know it's the valves, cause we did the whole oil thing to check if it was my rings.</TD></TR></TABLE>
that's what i thought, but on mine it was the valve adjustment that was giving me problems!
quik1 Dec 27, 2003 11:58 AM
Re: (smokey2.0)
I would check the valve adjustment first then follow it up with a leakdown to determine which valve it is.
^jefs0ng Dec 27, 2003 12:09 PM
Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">I would check the valve adjustment first then follow it up with a leakdown to determine which valve it is.</TD></TR></TABLE>
at ~30 bucks a set, I'm willing to replace all of them.. And I just got a valve adjustment no more than a month ago. Anything else I should do to "ensure" that it's my valves?
quik1 Dec 27, 2003 12:16 PM
Re: (.jefs0ng)
30 bucks for a set of valves or valve seals that seems low for a set of valves.
^jefs0ng Dec 27, 2003 01:12 PM
Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">30 bucks for a set of valves or valve seals that seems low for a set of valves.</TD></TR></TABLE>
43 for brand new valve seals + 25 for intake valves [not new].. so it's 78 bucks... still considering if I should replace the exhaust ones.. should.. I?
quik1 Dec 27, 2003 01:24 PM
Re: (.jefs0ng)
If there still fine I wouldn't even if I wasn't on a budget i'd just change the seals and your valve springs will be fine. Good luck. https://honda-tech.com/forums/images/smilies/embeer.gif
fulldragcrx Dec 27, 2003 06:21 PM
Re: (quik1)
if ya got any money left over, throw it my way, i sure could use it.
Alot of poeple just throwing money at a car lately, and alot of them are poor now with no car.
Anyone catching my drift?
^jefs0ng Dec 28, 2003 02:50 PM
Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">if ya got any money left over, throw it my way, i sure could use it.
Anyone catching my drift?</TD></TR></TABLE>
oh don't worry I don't have extra money, and if I did there people I'd rather give it to instead of some guy I've never met.
