question about di-electric grease
is there a need to use di-electric grease on spark plug wires for both connection points? or should I just slap the wires right on in?
Re: question about di-electric grease (skabone)
No need for di-electric grease at all.
Re: question about di-electric grease (hondatim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim »</TD></TR><TR><TD CLASS="quote">No need for di-electric grease at all.</TD></TR></TABLE>
Don't know about that. It sure makes removing the boots a hell of alot easier. |
Re: question about di-electric grease (Jim Truett)
Don't use di-electric grease. Use a little silicone spray on boots instead. Works better and won't make them greasy or fall off of spark plugs. Have seen customers try this before and have experienced this issue a couple of times with them.
Not saying you're wrong, Jim. Just saying, I've seen problems with this before. Good post though https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim »</TD></TR><TR><TD CLASS="quote">Don't use di-electric grease. Use a little silicone spray on boots instead. Works better and won't make them greasy or fall off of spark plugs. Have seen customers try this before and have experienced this issue a couple of times with them.
Not saying you're wrong, Jim. Just saying, I've seen problems with this before. Good post though https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> True. I don't usually consider the people who don't understand what a "light" application means. https://honda-tech.com/forums/images/smilies/emthup.gif |
