Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   ps belt (https://honda-tech.com/forums/tech-misc-15/ps-belt-878114/)
Mike banX May 27, 2004 03:57 PM
ps belt
how do i put a ps belt on my b18, the belt is to short for the distance from the pump pulley to the crank pulley, is there a way to adjust the pump pulley to bring it in clocer or something like that
kickerx May 28, 2004 12:35 AM
Re: ps belt (Mike banX)
ya you loosen the ps pump adjusting bolts to make it closer to the crank pulley...
Mike banX May 28, 2004 04:13 AM
which bolts are the adjusting bolts
JimBlake May 28, 2004 05:26 AM
Re: (Mike banX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike banX &raquo;</TD></TR><TR><TD CLASS="quote">which bolts are the adjusting bolts</TD></TR></TABLE>On mine, the 2 mounting bolts are in long slotted holes. Loosen them just enough so the entire pump can slide on it's mounting bracket.
Then there's a long skinny bolt up top, with a head like a wing-nut. When you unscrew that, it lets the pump slide down so you put the belt on. Tighten it to tension the belt, then tighten the mounting bolts.
dfoxengr May 28, 2004 06:46 AM
Re: (JimBlake)
just look on the braclet at which bolts hold the pump on.
