In process of BAR/ Reffing B16b in 98 Cx
#27
The Grumpiest
Re: In process of BAR/ Reffing B16b in 98 Cx
Jeezus. Just go down to the ref station and get it done. This is like not wanting to go to the doctor when you're sick because you're scared he might give you bad news.
#28
I sea foamed my motor before changing plugs and cleaning 02s. As for the tank I dont remember and am lazy to read my og post but if remember correctly I might have added lucas Injector cleaner a tank prior to going not sure. And my Nox level eas brought down after doing my mini tune up. And cleaning the inside of the intake manifold and near the entrance and exit of the valves. Nothing ti b afraid of. U only pay if pass $8. Just think of it as normal smog go stock with correct ecu cat ema ima emissions canister no codes all monitors on no bad wiring and youll pass. They dont wanna see you fail. Sorry. Writing this of my smartphone at work
#29
I appreciate the help. I have to get a stock fuel rail I have an aem one and was told it's not for for bar by my cousin. Thanks again man. I'll thank you once I get bar'd
Mr Grumpy man, sorry it you'd understand if you lived here in Cali. No hard feelings.
#30
The Grumpiest
I absolutely understand. You've got a jacked up setup and scared you won't pass BAR. So instead of making the setup right you want to find someway to cheat your way past it. I think I understand it pretty well.
Still don't understand why you people never call up the ref station and get the info from the horses mouth and not from friends and cousins.
#31
My cousin bar'd his ef... Wow man lighten up there's no way to cheat bar unless you have inside man. I want it to be done right and legal hence bar. Anyhow thanks op
#32
Finally found what I was looking for. Time to go drop the coin on a motor now. Thanks OP.
Sorry about bringing this back, but this info is valuable.
#33
steelrainwarrior
37
08-28-2007 07:40 AM
