Problems w/integra wire harness dash conversion
Yea I put an integra dash in my car. I have everything wired up but one of the clips to the fuse box didn't fit.(Pissed https://honda-tech.com/forums/images/smilies/emsad.gif ) The two clips that pluged up were the blue clip and the green one. The one that didnt fit was the gray one. The integra one has 15 wires. and the civic one has 13. I was wondering if anyone knew what the extra 2 wires were. And if anyone came across this problem or has the wire diagram for that clip. I need the civic one and the integra one if you got it.
Thanks 93Civic Hatch Si PS. I Searched everywhere for this shit couldnt find anything |
Re: Problems w/integra wire harness dash conversion (SiHatchTurbo)
what sort of civic is it?
waht colour are the left over wires? they may be for things like cat converter sensor or something... have you put power to it? what happens? |
I have a 93 Civic Hatchback Si
I solved my misfiring problem there still is the signals, the radio and the defrost. Blue w/red stripe and yellow |
Re: (SiHatchTurbo)
cant you trace the original wires on the back of the dash pod to see which wires go where?
ie check where the original civic connectors went on the connector and match this up to teh civic dash pod... this will tell you which civic wier operates teh bulbs in hte dash pod. tehn match these wires up to the integra dash pod by tracing the back of the dash pod... the colours should be standard across all honda's HTH t.. |
| All times are GMT -8. The time now is 09:53 PM. |
