Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   problems with #3 cylinder.. (https://honda-tech.com/forums/tech-misc-15/problems-3-cylinder-716691/)
Wide Open Throttle Dec 27, 2003 03:36 PM
my #3 cylinder is eating sparkplugs(electrode/insulator is melted/spotted, as if running too hot). my a/f gauge reads proper mixture under all throttle conditions, & the other cylinders seem to be running properly, although the other sparkplugs are looking whiter than i think they should. the sparkplugs are two steps colder than oem (for nitrous, but this problem is happening without the use of nitrous).
i switched the #3 fuel injector with the #1 injector, and judging from the #3 sparkplug it's still not running right. the #1 sparkplug (with the #3 injector installed) still looked just like cylinders 2 and 4, so the injectors seem to be fine.
i can't figure this out; any help is appreciated.
Modified by Wide Open Throttle at 2:53 AM 12/28/2003
Wide Open Throttle Dec 27, 2003 06:16 PM
Re: problems with #3 cylinder.. (Wide Open Throttle)
Wide Open Throttle Dec 28, 2003 01:12 PM
Wide Open Throttle Jan 1, 2004 09:26 AM
still looking for some help on this.
samdubs00si Jan 5, 2004 09:11 PM
My car is doing the same thing. I'm not sure what the problem is. I did a compression check and the rings are definately shot. There is also a valve problem, worn guides or bad seals.
It could be running too hot on that cylinder and if you have deposits on the plug as well, you could have oil getting into the cylinder.
Wide Open Throttle Jan 6, 2004 05:30 PM
Re: problems with #3 cylinder.. (samdubs00si)
i know i definately have oil leaking past the valve seals, could this be the problem?
my compression still reads very high in all four cylinders. the engine is supposed to have ~55 thousand miles on it.
any idea why it might be running hot in that cylinder? the plugs are two steps colder than oem.
thanks for the input
Wide Open Throttle Jan 7, 2004 11:07 AM
Wide Open Throttle Jan 8, 2004 10:52 AM
IN VTEC Jan 8, 2004 11:13 AM
The AF gauge won't pick up on a single cylinder lean condition b/c the sample it takes is based upon the average of all the cylinders' exhaust output.
Stick a IR temp gun on it and see how much the temp difference is b/w the exhaust runners.
Wide Open Throttle Jan 8, 2004 01:13 PM
Re: problems with #3 cylinder.. (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">The AF gauge won't pick up on a single cylinder lean condition b/c the sample it takes is based upon the average of all the cylinders' exhaust output.
Stick a IR temp gun on it and see how much the temp difference is b/w the exhaust runners.</TD></TR></TABLE>
well, i don't have an infared temp gun, but, i have figured out that what is happening is detonation at around 6000rpm at wide open throttle in the third cylinder only. but i still cannot figure out why, and i am not sure if it is due to ignition advance or a lean condition. the only way i thought it could be an ignition problem is if something was mechanically wrong with the distributor cap, and it seems to be in perfect working condition. so, at this point, im still thinking that it is because of a lean condition. i think the next step is to take the intake manifold off, check everything, and replace the gaskets.
thanks for the input. still looking for more!
IN VTEC Jan 8, 2004 01:31 PM
Maybe you should back off the ignition timing a little.
mattssi Jan 8, 2004 01:51 PM
What type of plugs have you been using?
mh Jan 8, 2004 01:58 PM
the #3 cylinder is the hottest. because of the way the water flows from#1-#4. think it migth just be running a bit lean
Jimmy Jan 8, 2004 02:16 PM
for one air fuel ratio gauges suck ass bro.. so i wouldnt go by them.. goodluck with your problem https://honda-tech.com/forums/images/smilies/emthup.gif
Btw: definetly do a compression test.
Wide Open Throttle Jan 8, 2004 03:41 PM
i have backed off the timing and i am using bosch platinums.
Wide Open Throttle Jan 9, 2004 11:25 AM
Wide Open Throttle Jan 9, 2004 05:05 PM
ultimatehonda Jan 9, 2004 07:59 PM
Alot of people I have talked to that have used bosch plugs have had problems....Maybe you should stick with ngk.
