Problem with my Idle
I have an 00 si coupe, and the idle RPM is less than 1000, but yet it pick back up. When i rev/gas it and let it go back to idle, the engine seems like it's about to die, then pick back up to about 500-900 RPM. Any suggestion on how to fix it or what the problem might be? THNAKS!
Re: Problem with my Idle (paowa)
Well, as with all idle problems, check your vacume lines.
Also, search for the IACV, and FITV valve. They both can cause wierd idle problems. |
| All times are GMT -8. The time now is 02:01 AM. |
