Powder coating block/head
I've been doing some powdercoating and really love it. My block and head will fit into my oven, and the powder coating can handle the temperature of the engine (I assume around 200-300 degrees at the most and the powder coating is good to 400+). The one thing I wonder is when I'm curing the powder at 400 degrees, will that screw anything up? I know when I replace valve guides I heat the head up to 250 degrees, but would 400 degrees warp the head/block at all? Any experience is appreciated.
Re: Powder coating block/head
95 views and no opinions or experience?
Google is your friend.
http://www.google.com/search?q=powde...ient=firefox-a |
Originally Posted by grumblemarc
(Post 46153111)
it would be a bad idea to heat the head up that high. valve seats and guides could come loose and you could end up annealing the aluminum. i don't imaging the block would be much safer... :crook:.
try using the high heat engine enamel. i've used it on valve covers many times and recently tried it on my F23 block. i'm very pleased with the results! there is a good variety of colors available too. |
Originally Posted by hondamark35
(Post 46158016)
Originally Posted by ZCHondaCRX91
(Post 46163911)
Okay, thanks. I might just try it on some spare heads and block to see if anything gets screwed up.
Originally Posted by rdssk8rcs1
(Post 46163944)
May not be visable to the eye
Any progress on this? Interested in the results.
