Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Piston weight within what range? (https://honda-tech.com/forums/tech-misc-15/piston-weight-within-what-range-1510777/)
allblackgsrt Jan 30, 2006 05:16 PM
I was weighing my pistons today. Should the pistons be + or - how many grams?
PyroProblem Jan 30, 2006 05:55 PM
Re: Piston weight within what range? (allblackgsrt)
What kinda pistons?
Ive weighed JE,SRP, and Wisecos and they were all within 1 gram of each other...
Eagle rods were all within 1 gram also...
allblackgsrt Jan 30, 2006 06:27 PM
Re: Piston weight within what range? (PyroProblem)
wiseco i got one 1.5 grams off is this a big deal
EnzoSpeed Jan 30, 2006 07:12 PM
You can probably keep playing around with the rods and pistons and get them matched up to within 1 gram.
I always weigh the pistons, pins, rods, and rod bolts separately, then mix and match them all. I can get each assembly to within 0.1 grams of each other.
EnzoSpeed Jan 30, 2006 07:14 PM
Re: Piston weight within what range? (EnzoSpeed)
Actually, 1.5g seems a bit off. You might want to file them to within at least a gram of each other first. I've never done it, so I forget where you're supposed to remove material though. I know there's a specific spot you need to file.
hxtasy Jan 30, 2006 07:41 PM
i would also like to know where you file them at
allblackgsrt Jan 30, 2006 08:16 PM
Re: (pennhatch)
thanks for the answers guys I searched just couldn't find anything
EnzoSpeed Jan 30, 2006 08:36 PM
Re: (allblackgsrt)
I know it comes off the wrist pin area. Ask this guy, he knows
https://honda-tech.com/zerouser...34604
Or you can always email Earl. He answers emails every day.
