Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   piston rings (https://honda-tech.com/forums/tech-misc-15/piston-rings-777734/)
DOHC VTEC EG Feb 23, 2004 07:40 PM
piston rings
for a 1.6 and 1.8 liter b series motor are the rings interchangeable between the 2?? i ordered rings for a gsr piston and decided to keep my p30 pistons. willthey work??
DOHC VTEC EG Feb 23, 2004 08:42 PM
need info asap
MEANB18 Feb 23, 2004 09:28 PM
Re: (DOHC VTEC EG)
no i don't think so.
98SpecR Feb 23, 2004 10:07 PM
Re: piston rings (DOHC VTEC EG)
yes they are interchangeable. both the b16 and b18 start off with the same bore 81mm. unless you have to go factory oversized 81.5mm.
vinasity Feb 23, 2004 10:12 PM
Re: piston rings (98SpecR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98SpecR &raquo;</TD></TR><TR><TD CLASS="quote">yes they are interchangeable. both the b16 and b18 start off with the same bore 81mm. unless you have to go factory oversized 81.5mm.</TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif
MEANB18 Feb 24, 2004 05:02 AM
ehh I just threw something out there. didn't know they actually were
vtecb20coupe Feb 24, 2004 11:38 AM
factory oversized 81.5 mm?
98SpecR Feb 25, 2004 11:25 PM
Re: piston rings (vtecb20coupe)
My Bust. I meant 81.25mm
