Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   pegged heat gauge? (https://honda-tech.com/forums/tech-misc-15/pegged-heat-gauge-1732358/)
ED9man Aug 24, 2006 08:16 PM
pegged heat gauge?
I just finished putting my trans back on, I go to start the car and the heat gauge goes all the way hot and stays there. Otherwise the car is fine. I did not have this issue before, also the cooling fan does not come on so I am thinking it has something to do with something inside the car. Any ideas? During the downtime I also had the center part of the dash out to put in the ciggarette lighter, everything worked fine at that point after I put it back together. Also my radio doesn't work not either. 88 CRX with B16a.
ED9man Aug 25, 2006 02:54 PM
Anyone? I am pretty sure it is not the sensor, since I have no CEL and VTEC will not work until the car is warm, despite the gauge reading. Also the cooling fan does not kick in. I really want to figure this out, I dont like not having a coolant temp gauge. Radio was unrelated, I checked all fuses as well.
bdavis Aug 25, 2006 03:56 PM
Re: (ED9man)
ummm, you fucked up something electrical.
get out the trust voltmeter and start tracing wires!!!
there are wiring diagrams all over this board. worse comes to worse, go buy a chiltons.
91SiZ6 Aug 25, 2006 04:13 PM
Plug your fan back into the harness.
ED9man Aug 25, 2006 05:17 PM
Re: (91SiZ6)
I'm pretty sure it's plugged in, but could that cause it?
ED9man Aug 25, 2006 07:31 PM
It worked perfect before I dropped the tranny.
street dreams Aug 25, 2006 08:01 PM
Re: (ED9man)
does it go all the way to hot even before u start the car w/ the key in the on position. if so when u where pulling the tranny out u damaged the thermo sensor on the side of the head under the distributer it looks like a headphone jack plug
91SiZ6 Aug 25, 2006 09:25 PM
I was going too quickly and forgot to plug my radiator fan back in. Exactly same symptoms. Could be a loose ground, too.
JDM_Ej Aug 25, 2006 11:51 PM
Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis &raquo;</TD></TR><TR><TD CLASS="quote">ummm, you fucked up something electrical.
there are wiring diagrams all over this board. worse comes to worse, go buy a helms.</TD></TR></TABLE>
Fixed. https://honda-tech.com/forums/images/smilies/emthup.gif
91SiZ6 Aug 26, 2006 03:39 AM
Helms is definitely the way to go if you can afford it. But having a Chiltons and/or Haynes is far better than nothing.
bdavis Aug 26, 2006 04:58 AM
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
notice i said "if worse comes to worse" get a chiltons. https://honda-tech.com/forums/images...es/emsmile.gif
Helms is the shit and for only $70, its by far the best investment if you plan on keeping the car for while. helmsinc.com
ED9man Aug 27, 2006 06:39 PM
I have a Helms. I am sure it is not the thermo sensor. My only question now is, does the wire for the gauge run straight from the thermo sensor or does it go through the ECU first?
bdavis Aug 28, 2006 05:47 AM
Re: (ED9man)
what does the wiring diagramd say
ED9man Aug 28, 2006 05:39 PM
Which sensor on the back of the block is the coolant temp? I checked the connections on both of them. There's one with 2 wires and one with one wire. Thanks.
