Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Pcv valve on b16 (https://honda-tech.com/forums/tech-misc-15/pcv-valve-b16-788441/)
NINJASPY Mar 4, 2004 01:40 PM
Pcv valve on b16
the pcv valve on my b16 has nothing connected to it, on the other side of the intake manifold its bare.... so its just sucking in air under the intake manifold...
where does the pcv connect from under the intake manifold? Its really tight behind there so I cant really take a look. If anyone has any pics or knows what parts I need to fix/replace parts that I am missing it would be grrreat!
https://honda-tech.com/forums/images/smilies/emthup.gif
RedlinedVTEC Mar 4, 2004 01:42 PM
Re: Pcv valve on b16 (NINJASPY)
Connects to the oil seperator box on the back of the block.
NINJASPY Mar 4, 2004 01:53 PM
Re: Pcv valve on b16 (RedlinedVTEC)
what kind of lines/hoses do I need/should use?
RedlinedVTEC Mar 4, 2004 02:59 PM
Regular vacuum line will work fine.
