Obd2 to Obd1 Conversion
if i throw the conversion harness and an obd1 ecu in my car can i expect it to run well after i tune it, or do i have nto completely rewire the the engine harness, and take out sensors?
Re: Obd2 to Obd1 Conversion (roachsboosted16)
All you need is the jumper harness should work just fine if you have no problems
An obd2 to obd1 jumper harness simply plugs in. No wiring needed.
| All times are GMT -8. The time now is 01:17 PM. |
