obd1 b18b valve cover to obd2 head
can you put an obd1 valve cover from a b18b onto an obd2 b18b head?
Re: obd1 b18b valve cover to obd2 head (povs9)
does anybody know, i really like the odb1 look over the obd2
Crankcase vent is different. Here's how I think it goes...
OBD-1 B18 has a vapor/oil separator box on the back of the block, with the PCV valve attached. Then there's only one fitting (to intake) on the valve cover. Your OBD-2 engine doesn't have that separator box on the block, so it needs both lines coming from valve cover. |
| All times are GMT -8. The time now is 08:48 PM. |
