Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   o2 sensor wiring. (https://honda-tech.com/forums/tech-misc-15/o2-sensor-wiring-837452/)
davidnguyen Apr 18, 2004 06:47 PM
o2 sensor wiring.
on the jdm first gen b16a...there are two o2 sensors on the header. how would i wire it to make it just use one of the o2 sensors? tia.
davidnguyen Apr 18, 2004 07:11 PM
Re: o2 sensor wiring. (davidnguyen)
anyone?
truent Apr 18, 2004 08:48 PM
you could just splice the 2nd o2 to the primary o2 wire at the ecu.. there is a reason for the two o2's btw.. but if say you're running aftermarket headers or something.. not much you can do.
EE_Chris Apr 19, 2004 05:58 AM
On the older B16's, the use of 2 O2's was to monitor 2 pairs of cylinders....so simply using 1 O2's output for both signals might introduce some hesitation/lag into the equation.
