Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Which NTK Spark Plugs (https://honda-tech.com/forums/tech-misc-15/ntk-spark-plugs-632726/)
7rrivera7 Sep 28, 2003 04:20 PM
Which NGK Spark Plugs
I have a built B16a in my CRX and I'm having issues with the plugs not lasting. I am currently using BCPR6ES.
Is this the right plug for an NA which sees weekly strip use? If not, what should be the NTK part number?
What if I want to squeeze a 75 shot? Should I use a colder NTK plug or how about a set of ZEX plugs? Which would be the colder NTK plug number?
Thanks!
Raul
Modified by 7rrivera7 at 6:10 AM 9/30/2003
7rrivera7 Sep 29, 2003 04:03 AM
Re: Which NTK Spark Plugs (7rrivera7)
Can someone help me?
TimoneX Sep 29, 2003 05:32 AM
You mean NGK?
You go up on the # to get a colder plug. For instance ZFR7F is colder than ZFR6F.
976 Sep 29, 2003 07:39 AM
Re: Which NTK Spark Plugs (TimoneX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimoneX &raquo;</TD></TR><TR><TD CLASS="quote">You mean NGK?
You go up on the # to get a colder plug. For instance ZFR7F is colder than ZFR6F.</TD></TR></TABLE>
NTK is the Japan version of NGK. Both use same materials and everything. The name change has to do with import traffifs and crap... Anyway. You need to go ZFR7F-11! These NGK plugs will solve your problem, esp. with n20.
TimoneX Sep 29, 2003 07:53 AM
Re: Which NTK Spark Plugs (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">NTK is the Japan version of NGK. Both use same materials and everything. The name change has to do with import traffifs and crap... Anyway.</TD></TR></TABLE>
Learn something new everyday. Those are the plugs I'm running currently. Best I've tried thus far.
976 Sep 29, 2003 08:10 AM
Learn something new everyday. Those are the plugs I'm running currently. Best I've tried thus far.</TD></TR></TABLE>
Yeah, they handle extreme heat very well..
7rrivera7 Sep 29, 2003 08:17 AM
Hey thanks 976. I'll go get a set today. I can use them for both NA and Nitrous right?
976 Sep 29, 2003 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks 976. I'll go get a set today. I can use them for both NA and Nitrous right?</TD></TR></TABLE>
Yup, they all will work for N/A and nitrious, However I recommend the version with 7 for nitrious, and 6 or 5 for N/A.
7rrivera7 Sep 29, 2003 10:04 AM
Last question...
These plugs seem to be made for non-vtec engines. I have a B16a. Should I still use these or BKR6E-N-11
TimoneX Sep 29, 2003 10:16 AM
Yeah the ZFRs are what's recommended for the B18a/b according to helms. I've used them and BKRs in my GSR and both were fine.
7rrivera7 Sep 30, 2003 04:56 AM
Do you know the difference between BKR6E-11 and BKR6E-N-11?
My local Pep Boys only has the BKR6E-11's
7rrivera7 Sep 30, 2003 10:14 AM
Anyone know the difference?
JimBlake Sep 30, 2003 12:55 PM
I've got a list that says the N means "special side electrode", but it doesn't say WHAT's so special about it...
