Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   no spark (https://honda-tech.com/forums/tech-misc-15/no-spark-1962692/)
slvrcvc93 Apr 23, 2007 01:49 PM
no spark
Other than the distributer is there any thing else that will cause no spark or weak spark ???? ecu is in swapped the dizzy still no spark id raterbuy another one than just swapping the coil. i dont know if theres a relay or a fuse just askin unless i have 2 bad distributer chances are small but anything is possible
HAMOTORSPORTS Apr 23, 2007 03:03 PM
check to see if you have fuel. If you don't chances are the main relay is bad.
slvrcvc93 Apr 23, 2007 06:59 PM
Re: (HAMOTORSPORTSUSA)
Sorry man lots of gas have a walboro pump i hear it when its on and i pulled the rear line of the regulator defintly enough gas
BILLETGRIP Apr 23, 2007 08:21 PM
Re: (slvrcvc93)
check all your grounds. same thing happened to me. i bought 3 dist. before my dumbass realized i didnt connect the ground goin to the thermostat housing.
slvrcvc93 Apr 24, 2007 11:27 AM
Re: (BILLETGRIP)
Nah checked that have grounds im gonna swap dizzy with a friend to see if that works hopefully it will
