Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Need tips on building B16 (https://honda-tech.com/forums/tech-misc-15/need-tips-building-b16-289677/)
Si Sep 25, 2002 10:33 AM
Need help on this. Would it be a good idea to bore the engine from 1.6 to 1.8-2.0, resleeving, change the heads and the rods...ect. Would it be a waste of money? or should I just buy a bigger engine. I'm planning to go turbo but I don't think 1.6 would be good enough. Thanks http://images.zeroforum.com/smile/emthup.gif
Spade Sep 25, 2002 10:37 AM
Re: Need tips on building B16 (RedSi99)
CTR cams.
GE Sleeves to 86mm bore
Forged Pistons 9:1 compression
Eagle rods
But, I think you should sell the B16 and Buy a B18C1 and do it to that. The longer stroke will add to the displacement.
[Modified by Spade, 11:38 AM 9/25/2002]
MisterB Sep 25, 2002 10:38 AM
you can not bore a b16 to 1.8 because the bore sizes are the same if you want it 1.8 you will have to stroke it http://images.zeroforum.com/smile/emsmilep.gif whick in my opinion is not worth all the money it will cost... do a search plenty of people go very fast with b16 NA and FI
