Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   need help from some engine builders (https://honda-tech.com/forums/tech-misc-15/need-help-some-engine-builders-2251272/)
superfast666 Mar 15, 2008 05:23 PM
ok to start of it a ls b18b1 stock completley rebuilt new bearings new rings new gaskets new water pump oil pump and so on. my problem is i had it assembeled and they and come to find out the cylinders were not honed and when i started the motor it ran perfect then i go to start it again and smokes like a bitch there is blow by in the cylinders my question is if i take it all apart and have the cylinders bored within the service limit can i reuse the rings and if i do will they seat properly
civicstar Mar 15, 2008 10:08 PM
Re: need help from some engine builders (superfast666)
i usually never reuse rings even after a simple start, usually if u let it idle for about 20 mins it will start to seat and then the perfect A/F will allow for a good break in after that, but just get some new ones
superfast666 Mar 16, 2008 02:22 PM
Re: need help from some engine builders (civicstar)
anyone else think i would be ok with the same rings
PolishSasquatch Mar 16, 2008 05:49 PM
if all you did was just start it and run for a couple minutes, im pretty sure you can just reuse them
KENetics1 Mar 16, 2008 06:03 PM
did you forget to have the cylinders honed or did the machine shop forget to do it?
superfast666 Mar 16, 2008 08:22 PM
Re: need help from some engine builders (KENetics1)
now im not sure because im only getting blow by in 2 cylinders im gonna pull the pistons and see if the rings are staggered correctly does any one know if u can get blow by if the rings are positioned at the pin or thrust surface
riceburner700 Mar 17, 2008 09:53 AM
if you bore/hone your cylinders your piston ring gaps are gonna be off. as cheap as rings are just get another set
