Need Help with parking light
i just got my car...and i dont know too much about it...
but i wanted to make my parking light/turning light both turn on at the same time like this pic below.... https://i100.photobucket.com/albums/...9/000_0526.jpg instead of just the parking light being on like this below.... https://i100.photobucket.com/albums/...sc00802pn4.jpg ummm yeah i searched...but found nothing...any help would be great!! thanks -pete |
Re: Need Help with parking light (four-eyez)
One way to do this would be to add a relay (SPDT) to each side. These can be bought any Radioshack or local auto parts store. It will add power to the turn bulbs with parking lamps on, and turn the bulb off when it sees power to the turn signal power wire. I drew this up to show you how it gets wired in. Where in the circuit, and where you mount these, is entirely up to you.
http://myspace-623.vo.llnwd.net/0152...28104623_l.jpg Good luck https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Need Help with parking light (Rigginit)
uhh i kinda dont get it...but i dont know what in the world a relay is so...hopefully when i go buy one...i'll have a better vision on what to do...
also will it blink when i signal? or will it remain lit? haha thanks https://honda-tech.com/forums/images/smilies/emthup.gif |
Yea it will blink with the signal. And yes as well when you get a relay you will see that looking at the prongs from the bottom side, they will line up just like the diagram drawn. If it wasnt cold and snowing here Id get you the actual wire colors and let ya know which terminals they go to. http://images.honda-tech.com/set1//smile/emcrook.gif As for the blinking... it just reverses the effect of the bulb ...as in when your blinker flashes on it turns he power off and it comes back on when flasher power stops. Easier way to under stand it= normally light is -> OFF - on off on off on off <- with flasher. This way it will be -> ON - off on off on off on <- reverse of how it would be, but still operating perfectly like it normally would
What the hell is 87b did you just make that up lol
http://www.the12volt.com/images/relaytext.gif If you wire it like you showed him in this pic http://myspace-623.vo.llnwd.net/0152...28104623_l.jpg The front and rear blinkers will be out of phase with the parking lights on... With the parking lights off your front blinkers will not work https://honda-tech.com/forums/images...s/emsmilep.gif Modified by Danny_EJ at 6:13 PM 12/7/2006 |
Re: (Danny_EJ)
oops lol.... ya what he said https://honda-tech.com/forums/images...s/emsmilep.gif been a while haha
*Mental note to self* no more posts after 1am while tired lol |
| All times are GMT -8. The time now is 10:27 AM. |
