Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   minime help (https://honda-tech.com/forums/tech-misc-15/minime-help-1227720/)
90crxmike Apr 27, 2005 03:56 PM
minime help
i have a problem i didnt have a map sensor before so my motor would shut off wouldnt hold an idle and that was it and know i got the map sensor i dosent shut off but the idle bounces and the temp goes up right before the max then i shut it off wut could it be
Kendall Apr 27, 2005 07:22 PM
First off, give the entire cooling system a good inspection. Once you get the temperature stabilized, then check for vacuum leaks.
CRXDrew Apr 27, 2005 10:18 PM
shit man... sounds like a bad install. Make sure you got coolant in her... and maybe perform a compression test....
Be more clear when you post. Organize your thoughts and display them legibly. You get way more answers that way.
For a second I wasn't gonna post after reading... but its late and I'm procrastinating on a paper... and I was in your shoes before... minus the car problems https://honda-tech.com/forums/images...s/emsmilep.gif
