mini me dont understand this
So I did a mini me and it started but would die if I didn't stay on tue gas now it doesn't start I have fuel air and no spark I've timed and timed it nothing works this car is prob after prob after prob if I can't fix this im junking this piece of shit
Re: mini me dont understand this
Not enough info.
How about this
Its a d15b1 block z6 head pr3 ecu chipped tuned pm6 intake manifold crx si dizzy I have fuel squirting when I take the fuel rail line off I seem to have no spark but the car turned on earlier |
So troubleshoot for no spark.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/ |
im
having the same problem check the dizzy or your wiring if your wiring is good the its ypur dizzy |
Originally Posted by m3kid
(Post 47299890)
im
Originally Posted by EF2SLOW
(Post 47300451)
my dizzy was working great on my d15 head I don't understand it has to be timing what I think
or it could be your timing you need an adjustable cam gear and advance it 4.5 degrees for the 'half of tooth off' but if you already did then its your dizzy you need a z6 dizzy
also it would be better if you did an obd0 to obd1 conversion harness
(Post 47306173)
And can't I just cut the injector plugs and distributor plugs and wire the obd1 up directly? |
(Post 47306607)
yeah I know I've just been so dam broke lately. I have a vtec converted p06 chipped and tuned and a z6 distributor and z6 injectors and fuel rail
nahh i mean you could and there is write ups out the but trust me save your time and buy a conversion harness atleast a cheap one from ebay or if you want a good quality one buy the one off ebay from mono tech everything is easy with his harness
(Post 47316189)
| All times are GMT -8. The time now is 02:46 AM. |
