Lsvtec conversion questions?
I'm new into the import scene. I did my search but still alittle confuse?
As of right now I have a 1993 civic egg with B18b ls motor. And I just bought a 1999 GSR vtec cylinder head and wanted to convert it to lsvtec. My first question is could i still use my DC sport 4-1 LS header or would i have to buy a new one? Second, could i still use my AEM Ls cam gears or would it not work with my GSR head? Are the cam gears different? Last question is that my GSR cylinder head need a distributor, i think its OBD 2 but i was thinking of keepin it obd1. Could a 94-95 GSR OBD 1 distributor work on my 99 GSR head? Pretty much i dont know much about cars or engine parts so any info or help would be greatly appreciate. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Lsvtec conversion questions? (B18BEGG)
no reply ... https://honda-tech.com/forums/images...s/emthdown.gif dang...
you can use the same LS header, same AEM LS cam gears, and you can use an obd-1 gsr distributor, all with no problem.
Re: (soulstream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulstream »</TD></TR><TR><TD CLASS="quote">you can use the same LS header, same AEM LS cam gears, and you can use an obd-1 gsr distributor, all with no problem.</TD></TR></TABLE>
well he summed it up pretty good. but you will also have to do something about those dowel pin holes or the dowel pins themselves. |
Re: (SprayinCX)
for dowel pins you can get the eagle dowel pins so you dont have to pay a machine shop to drill the holes out.
Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">for dowel pins you can get the eagle dowel pins so you don't have to pay a machine shop to drill the holes out.</TD></TR></TABLE>
but what head gasket would you use? i know the golden eagle dowel pin you have to you their head gasket with them. because a oe ls gasket, the holes are to small for the pins to go through.(i speak from experience) |
Re: (SprayinCX)
Thanks alot for replying back guys. I appreicate.
Now I know I could pretty much get my project going. ANd yes I'm planning to get the Golden Eagle Lsvtec Kit. Again thanks . https://honda-tech.com/forums/images/smilies/emthup.gif |
| All times are GMT -8. The time now is 03:51 AM. |
