ls and Gsr block component compatabilites?
I am building a ls/vtec and i have a bare ls block, how much of the stuff off the gsr block will bolt up to an ls block. Parts i am wondering about are the t-belt tensoiner, theromastat houseing, the water tube in back of the block, sensors, and oilpan. I am guessing they are all the same i just want to double check, so i know what to order from acura.
thanks mike https://honda-tech.com/forums/images...es/emsmile.gif |
Re: ls and Gsr block component compatabilites? (dwn-shift)
I know you can put the GSR oilpan on your LS block. Pretty sure (but not 100%) the sensors can be used as well.
Re: ls and Gsr block component compatabilites? (xThexHeadx)
All that stuff will work. I have a water pipe and a brand new tensioner still in packaging if you need.
Re: ls and Gsr block component compatabilites? (Quik Chris)
All that stuff will work. I have a water pipe and a brand new tensioner still in packaging if you need. thanks mike https://honda-tech.com/forums/images...es/emsmile.gif |
What are your plans with that GSR block once you strip the stuff you need? https://honda-tech.com/forums/images...es/emsmile.gif
Re: ls and Gsr block component compatabilites? (CRX PAT)
What are your plans with that GSR block once you strip the stuff you need? https://honda-tech.com/forums/images...es/emsmile.gif Mike |
I thought the GS-R oil pan was different because of the block girdle? Or do you only need the different oil sump that goes with it to make it fit?
Re: ls and Gsr block component compatabilites? (94IntegraGSR-OVR)
You can put a GSR oilpan on an LS block, but you cannot an LS pan on a GSR block. Thats because of the block girdle that you mentioned.
sweetness, ill be doing the same thing this coming fall...great post!!!
Re: ls and Gsr block component compatabilites? (drumking15)
one minro question of concern..woudl this work on a b18a?
I think the b18a and the b18b are the same block.
Mike |
Yeah, pretty much.
| All times are GMT -8. The time now is 03:29 AM. |
