Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Lower engine mount questions (https://honda-tech.com/forums/tech-misc-15/lower-engine-mount-questions-3383404/)
Deadpixle Feb 1, 2026 11:26 AM
My lower front torque mounts on my 2001 GSR are completely torn. I am guessing the transmission mount must also be bad. I'm planning on getting new lower mounts next week. I want stiffer torque mounts. I was thinking Megan as they look OEM but use stiffer rubber. I might go with a billet mount with stiff poly bushings. My question is, if I use stiff front torque mounts, do I need to use a stiff rear transmission mount too? Will it cause an OEM rear mount or the upper mounts to fail by shifting the load to the softer bushings?
