jdm Honda Integra type r RPM sticking
I just got my dc5 today. It seems to hesitate with half throttle around 3700 rpm and then goes fine. At full throttle it goes nicely. The clutch catches high to me, it has 90k miles and I had Honda check it before I bought it and they said it was fine. I haven't had a Honda in a while, anyone else's clutch catch high. It seems to catch fine. The guy I bought it from said he did not have his issue but that it may be a dirty O2 sensor. He also said his buddy said in Japan these cars are tuned to 95 octane and that could have caused the O2 sensor tonbe dirty. There is no CEL. My other buddy said it could be IACV. What do you guys think?
Re: jdm Honda Integra type r RPM sticking
Old Fart
Ditto the above^^^ the normal diagnostic checks need to be done, compression test, valve lash adjustment, check the fuel pressure, check the spark, use only an HEI spark tester, [around $10 at any auto parts store] spark needs to be bright blue.
Check timing confirm both mechanical and electrical timing. 94
