Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   itr compression ratio.. (https://honda-tech.com/forums/tech-misc-15/itr-compression-ratio-390933/)
p-boy Jan 20, 2003 08:08 AM
im buying a jdm motor itr.. how much compression should i look for? i mean in the gauge it will sayo something like 180 or something how do i convert it to like 11.5 or something?.. and whats the stock compression ratio of the jdm itr motor? in psi plsss..
b18cya Jan 20, 2003 08:36 AM
Re: itr compression ratio.. (p-boy)
http://www.bseries.net/html/specs/benginespecs.php
B18C 96+ Spec-R /
98+ Spec-R JDM 96-00 Integra Type-R (JDM)
1797cc
DOHC VTEC
11.1:1 c.r.
sgT Jan 20, 2003 10:35 AM
you cant convert compression test numbers into an actual compression ratio.
Too many variable factor in which make it near impossible to guess.
Just look for around 200-220 on the comp tester and make sure all 4 are within 5-10 of each other
leadfoot78 Jan 20, 2003 10:45 AM
Re: itr compression ratio.. (sgT)
If its out of the car cold and motor is turned by hand look for 130-150 psi. Thats what my JDM GSR did when i turned it by hand after i put it in the car turned it on warmed it up and turned it with the started it did 220/210/215/215.
1bad-eg Jan 20, 2003 02:00 PM
Itr block should be at about 240 psi.
p-boy Jan 20, 2003 03:26 PM
Re: itr compression ratio.. (1bad-eg)
well? guys? 220 ? or 240? if i turn it by hand?
leadfoot78 Jan 20, 2003 10:13 PM
The manual says that 184psi is the minimum so if you are above 200psi it's fine.
