Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   idle problems (https://honda-tech.com/forums/tech-misc-15/idle-problems-1704095/)
scotts93ls Jul 27, 2006 09:45 PM
idle problems
i have been having problems with my 93 ls. the idle jumps from 1500 to 3000 and back to 1500 then to 3000 constantly. i have serched for a vaccum leak many times. i have replaced the tps, iacv, intake manifold gasket, tb gasket, and still runs the same. i am lost for what to look for next. i went though the pcv system from that little black box on the back of the motor to the intake manifold but no leaks there. i was just wondering if anyone has had this problem or what i would be able to test next. could it be something with the computer? could the computer terminals get corroded for the water that leaks in durning the rain and cause the computer to not be getting the correct info? and ideas let me know..???
Acura_I-RS Jul 28, 2006 09:12 AM
Re: idle problems (scotts93ls)
that little fitv valve under the TB, take the cap off the end of it, and twist the little white valve back in, they get loose soemtimes, worked for me
Takumi Fujiwara Jul 28, 2006 10:00 AM
Re: idle problems (Acura_I-RS)
sometimes it's the little shit that makes the idle do that. Mine was surging from 1k to 2.5k, needless to say, it was frickin annoying and at part throttle it wasn't that smooth.
After spraying carb cleaner all over the TB and IM gasket area, double check FITV, etc...
It ended up being the freak throttle cable. I had it a little too tight. Cable needed a little bit more slack than I gave it.
scotts93ls Jul 30, 2006 07:37 PM
thanks for the replys, i will give them a try, i know its not the cable that has more then enough slack in it but that screw i will try
thanks again
