How long are ctr rods?
supposedly its an b18c block w/ b16 crank right?
Re: How long are ctr rods? (cheapEG)
Yes, it is a B18C/P72 block with a 1.6L crank and longer rods. It is a 1.6L crank, but it's not exactly 1.6L crank out of a B16A engine; it's a special 'R' prepped 1.6L crank, which is made along the same procedure as the ITR crank, and is specifically designed for the P72 block+crank journals. This B16B crank has a less-width journal area, same as you'd find on a GSR or ITR crank; and its counterweight balanced. Regular B16 cranks have wider crank journal area's and are not counterweight balanced.
I don't have the exact length specs on them, but I do know for a fact that they're the longest b-series rod. I've compared them to B18C rods and they're a few cm's longer. [Modified by Katman, 9:01 AM 11/18/2002] |
Re: How long are ctr rods? (Katman)
If I remember they're 144mm.
Re: How long are ctr rods? (B18C-EJ1)
If I remember they're 144mm. |
That sounds about right... I thought the R/S of a CTR was like 1.84 and with a 144mm rod it's about 1.87.... Oh well when i find out for sure i'll post back up... Peace http://rely.net/~htimages/smile/emsmile.gif
This B16B crank has a less-width journal area, same as you'd find on a GSR or ITR crank; and its counterweight balanced. Regular B16 cranks have wider crank journal area's and are not counterweight balanced. |
Re: How long are ctr rods? (sgT)
This B16B crank has a less-width journal area, same as you'd find on a GSR or ITR crank; and its counterweight balanced. Regular B16 cranks have wider crank journal area's and are not counterweight balanced. Only the rod journals are wider. the mains are the same. ahh yeah, ok..thanks. I knew there was some differences between B18C/CTR and B16A crank journal widths somewhere.....thanks for the clarification. |
Bumping the thread.
b16b rods use 142.42mm rods with 77.4mm crank. 142.42 / 77.4 = 1.84 Anyways, i have this query - if we use an 87.2mm crank from a b18c with b16b rods we would have a 1.63 stroke ratio - more stress upon the cylinder walls, BUT... What im trying to achieve is a better stroke ratio for a b20 capacity - which from factory has a 1.53 stroke ratio (137.01mm rods and 89mm crank) I am wanting to utilize... B16B Civic Type R rods 142.42mm long B18C Type R Crank 87.2mm Stroke and a sleeved 84 or 85mm B16b or b18c series VTEC block. My question is, with that setup^ are [aftermarket b20 84/85mm] pistons going to clear the valves? Probably not. Custom pistons with pins located higher in the piston I'm guessing? |
| All times are GMT -8. The time now is 04:14 AM. |
