Car bogs out until it is fully warmed up
Old 11-02-2008, 06:11 PM
Rukusmasta2's Avatar
Default Car bogs out until it is fully warmed up
My buddies car bogs out and misfires until the engine is fully warmed up. No CEL's and after its fully warmed up runs fine. What can be the cause, what should i check or replace.
Old 11-03-2008, 02:48 PM
Default Re: Car bogs out until it is fully warmed up (Rukusmasta2)
BUMP
Old 11-03-2008, 03:28 PM
GhostAccord's Avatar
What type of car is your buddy driving? Make/Model/Year.
Sounds like a fast idle thermal valve or it could be low coolant. I'd need to know what engine and throttle body set up is being used to take a better guess.
Old 11-03-2008, 04:00 PM
Default Re: Car bogs out until it is fully warmed up (GhostAccord)
96 EK b16 stock TB. and its not the IACV it was messed up and replaced with a good one.
Old 11-03-2008, 04:14 PM
How does it start/idle cold with the IACV disconnected?
Did you bleed the coolant system after you changed the IACV?
Old 11-03-2008, 04:51 PM
never tried that,yes
Old 11-04-2008, 02:01 PM
Old 11-04-2008, 03:17 PM
Mad Scientist
mmuller's Avatar
o2 sensor?
Old 11-04-2008, 04:56 PM
Default Re: Car bogs out until it is fully warmed up (mmuller)
woudlnt a faulty o2 sensor throw a code
Old 11-04-2008, 06:57 PM
Mad Scientist
mmuller's Avatar
not all the time, usually you would see heater codes. but..
af could be lean till o2 heats up.
does it missfire badly?
chris d
09-10-2015 03:35 PM
scooter2525
13
12-30-2013 05:23 AM
kpop
02-18-2008 04:40 PM
kHoA DoGG
10-31-2002 11:44 AM
Quick Reply: Car bogs out until it is fully warmed up
