How to install Autometer gauge - voltage meter?
Shell: 93 Civic Cx
Motor: 98 GSR / OBD1 p72 ECU Just purchased 3 gauges for the Hybrid (oil press / water temp / voltage). Wondering how to install the voltage meter once it arrives Picked up this one (ATM-4791): https://static.summitracing.com/glob...atm-4791_m.jpg Thanks for any useful info https://honda-tech.com/forums/images/smilies/embeer.gif |
Re: How to install Autometer gauge - voltage meter? (Hybrid93Hatch)
One wire to ground, another to a switched positive circuit.
rmc |
Re: How to install Autometer gauge - voltage meter? (WundedSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WundedSaint »</TD></TR><TR><TD CLASS="quote">One wire to ground, another to a switched positive circuit.
rmc</TD></TR></TABLE> Going to finally install the gauges this weekend. Where is a close switched positive to the center console? Thanks! |
tap the clock harness for power, easiest clip to get to
-Bryan- |
Personally, I would run that gauge straight to the battery's positive post.
I would prefer an accurate voltage level at the battery, and it is proven that you lose a bit of voltage going through the car's electrical system. |
or i believe there us a switch 12v source on the fuse block.
Re: How to install Autometer gauge - voltage meter? (mntuner2)
2 Questions, does an ammeter install the same way? And how did you wire up the gauge lighting?
No; the ammeter basically sits between a large high-current power cable.
And the lighting wires are wired the exact same as the other gauges; on a switched 12V line. |
| All times are GMT -8. The time now is 11:14 PM. |
