How does one install a Secondary Fuel Rail for Victor X manifold?
I am looking for a secondary fuel rail for my Edelbrock Victor X intake manifold . I did find a part number from an older thread and called Edelbrock with it . I was told by Edelbrock that the said part was no longer available . So this brings me here to ask if anyone has done this and what worked for them . It is rather frustrating to have to make my own . I would love to avoid that if possible . Thanks in advance .
Moderator
re: How does one install a Secondary Fuel Rail for Victor X manifold?
Why one is needed in the first place is the underlying question that needs to be answered, so more information on your end is needed first.
Re: How does one install a Secondary Fuel Rail for Victor X manifold?
In a nut shell my current id 1000's are completely maxed out when im at the track running c16 with 2 fuel pumps . I want to make the switch to e85 . The car does see street use and i do like to run pump gas when doing so . A good flex fuel setup is what i am currently building for the car . I know 1700's and bigger will run like crap on pump gas with my little 2 liter engine . So running two sets of 1000's will do the trick for me .
Really ??? My understanding was 1300's were at the limit to have excellent drivability on the street with pump . I consulted with Jeff Evans and he told me otherwise . Odd . I am going to be using an Infinity as well so i know that will be better than stock ecu based tuning .
yea I would just go to a larger injector myself. but if you really want an 8 injector set up. you can look into the Pro Jay 8 injector manifold. looks similar to the Victor X
Redirect Notice
Redirect Notice
Fish Twig
edelbrock has a manifold that does 8 injectors
BUT, you never said what you drove
edit: gah, i skimmed....
the 4 injectors go under their manifold under each runner
LS1Bait
01-15-2009 07:04 AM
