HELP.....trans/clutch problem?
Ok, the engine is done and back together. currently have a clutchnet full race pressure plate, clutchnet carbon-kevlar disk clutch, and CM flywheel. while the engine is off, it rows through the gears fine, but clutch wont engage at all with car running. the fluid is topped off, and we bled it several times. any ideas?
Re: HELP.....trans/clutch problem? (integRated109)
did you check the t/o bearing??
Re: HELP.....trans/clutch problem? (salbaje)
any grinding?
sounds like the throw out bearing or the arm isnt installed correctly. |
Re: HELP.....trans/clutch problem? (KAMiN)
no grinding at all, it just wont go into gear. clutch pedal still has massive pressure. throw out bearing wasnt new, but only has a hundred or so miles on. well probably change it tomorrow just to see. i can see the arm moving on the front of the trans. but it seems like it isnt quite moving far enough. would a throw-out bearing cause this sort of problem?
P.S....KAMiN, im coming for you guys SOON http://images.zeroforum.com/smile/emwink.gif |
no grinding at all, it just wont go into gear. clutch pedal still has massive pressure. throw out bearing wasnt new, but only has a hundred or so miles on. well probably change it tomorrow just to see. i can see the arm moving on the front of the trans. but it seems like it isnt quite moving far enough. would a throw-out bearing cause this sort of problem? P.S....KAMiN, im coming for you guys SOON http://images.zeroforum.com/smile/emwink.gif i hate this city no fast cars, and there all ricers. anyway. did you grease the throwout bearing? |
Two words: ClutchNet.
Re: HELP.....trans/clutch problem? (Rocket)
top
This is for everyone's viewing enjoyment. This is Integrated109 having just a little too much fun with his new 3" exhuast and New Motor last night before the clutch.
http://www.speed-factor.com/Pic0008-1.jpg http://www.speed-factor.com/Pic0011-1.jpg |
Re: HELP.....trans/clutch problem? (Hyundai4G63T)
LMAO, thats some funny shit
YEAAAAAAA.....the beast is alive. anyone ever try to bleed a clutch with a full race pressure plate? we had to stick a pry bar behind the ramp and compress it that way.
It could be a bad slave cylinder...
| All times are GMT -8. The time now is 04:17 PM. |
