Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   help (https://honda-tech.com/forums/tech-misc-15/help-2632516/)
912 Aug 22, 2009 09:06 PM
help
i have a b18b1 i compression tested it today its 170psi on all 4 cylinder is that ok, also my friend is rebuilding his gsr and bought rod berings and main berings brand new in box off kid on craigslist, when we looked up part number it said it was for ls, is there a difference between gsr and ls bottom end rebuild kits
912 Aug 22, 2009 10:54 PM
Re: help
any one
912 Aug 23, 2009 08:46 PM
Re: help
bump
912 Aug 24, 2009 05:30 PM
Re: help
no one no
912 Aug 27, 2009 07:01 PM
Re: help
what the **** no one fuk all yall
srmofo Aug 27, 2009 07:16 PM
Re: help
well first off, your title is generic and most will not respond to that kind of lameness. second since you want to be a childish dick because noone respondrd to you, figure out your own bearing issue. its not that hard. if you can look up a part number for one part then Im sure you can do it for another
