headlight problem help please !
The problem is both headlights turn on if they are set up on highbeam , but when i leave them on low they will not turn on. The fuses are fine . I also tried some extra bulbs of my friend's car that were working and same thing happend when in my car . Any ideas ?
Re: headlight problem help please ! (purple_ek9)
start tracing wires, maybe your high/low beam switch in your steering column
ill check that out too thanx
not trying to jack yout thread, but, yea, i have the same problem, the low beams dont work so i rock high beams all the time. The thing is i took the advice of other people to check the bulbs, and replace the it with new healight harnesses. Still im having the same problem. anyone else have any ideas.
| All times are GMT -8. The time now is 05:17 AM. |
