Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   got the ELD code what do i do to fix. (https://honda-tech.com/forums/tech-misc-15/got-eld-code-what-do-i-do-fix-457204/)
KevronsEG Mar 28, 2003 09:52 AM
i just swaped my d16z6 into my crx si. converted to obd1. what does.it mean and how do i fix it? thanks
omahaturbocivic Mar 28, 2003 11:59 AM
Re: got the ELD code what do i do to fix. (CIV616)
It is because your car does not have an eld. It would be located under the fusebox in the engine bay I believe on a car equipped with one. It however does not effect anything and should not cause a check egine light, it just stores a code. Most people do not worry or do anything about it.
crxludeT66 Apr 22, 2003 04:49 PM
im haveing probs with code 20 and it wont go away. it throws the ecu into safe mode and will not rev past 4000 rpm.my car is a 96 obd2 civic with a obd1 b18b non vtech engine . my car from factory does'nt have the eld unit in the fuse box how can i bypass the eld unit so it does'nt flash this code anymore
