Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Fully built motor running rich on startup... help (https://honda-tech.com/forums/tech-misc-15/fully-built-motor-running-rich-startup-help-1663446/)
Rob! Jun 18, 2006 06:58 AM
hey guys i just got my low compression lsvtec motor back and put it in... im running stock bseries injectors, walbro 255hp fuel pump and stock sohc ecu because i wanted it to run leaner.... when i started the car my wideband read 14.7 then after 5 seconds of running it worked its way down to 10.0 i imediatly shut the car off because its a brand new motor and i didnt want to wash out the rings. there is a aem fuel pressure regulator on the car set to 40psi. i dont think that would cause the car to run so rich. any ideas on what i can do to make it run leaner because i want the rings to seat properly.
edit: ecu is a p06 and i am getting no engine codes.
Magick211 Jun 18, 2006 07:23 AM
Re: Fully built motor running rich on startup... help (Rob!)
Bump for a answer
qfast817 Jun 18, 2006 04:35 PM
Re: Fully built motor running rich on startup... help (Magick211)
check the fuel presure regulator, theres a diaphram that is know for going out
Rob! Jun 18, 2006 06:04 PM
Re: Fully built motor running rich on startup... help (qfast817)
i dont think its the diaphram...any other ideas?
xerox445 Jun 18, 2006 06:09 PM
robo, the engine is going to run rich till its warmed up, its in cold start enrichment...unless you jump out the IAT and ECT sensors your going to run rich for a little
Magick211 Jun 18, 2006 06:34 PM
Re: Fully built motor running rich on startup... help (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">robo, the engine is going to run rich till its warmed up, its in cold start enrichment...unless you jump out the IAT and ECT sensors your going to run rich for a little</TD></TR></TABLE>
Yeah but isnt 10:1 a/f way to rich?
Magick211 Jun 19, 2006 01:00 PM
Bump for more suggestions
Wafler Jun 19, 2006 02:12 PM
My oem FPR was fubar and the car was mad rich on startup (and at all times for that sake). I doubt the oem FPR can deliver 40psi even with no internal contents so get that FPR checked https://honda-tech.com/forums/images...es/emsmile.gif
Rob! Jun 19, 2006 03:56 PM
Re: (Wafler)
i put a stock pump in, changed the regulator even put the fuel pressure down to like 15 psi and it still runs at constant 10.0. i pulled the plugs and they were dripping in fuel so i know its not a bad wideband.
When i put the stock injectors in the car i un installed my resistor box and put all of the 8 wires that go to the dead clip and soldered them together. i dont know if this is the correct way to take out the resistor box but i think the injectors have to be constantly dumping fuel.
Magick211 Jun 22, 2006 12:10 AM
Re: (Rob!)
Bump....
