Fuel rail bolts or studs. Where to buy? m6x1.00x22mm bolts
So min intake manifold doesn稚 come with the studs to hold the fuel rail bolted down into intake manifold
i found the dimensions are m6x1.00x22mm Now I知 trying to eBay them but no real luck
I think I知 sure I can find at my local hardware store. But they would not be the socket size oem 10mm. Itd be 11 or something along that nature.
Any recomondation on where I can buy that keeps 10mm?
Re: Fuel rail bolts or studs. Where to buy? m6x1.00x22mm bolts
you talking about the 3 bolts the hold rail to intake? if that's the one's you are talking about, I got a box of them from AutoZone.
I would just pick up some OEM ones, new or used. For example you can get the m6x1x28 (I realize its slightly longer) stud from Honda brand new & you can even get the m6 nut that is for it as well. These are the factory fuel rail studs for a 99 civic Si, this way you can keep the 10mm that you are wanting with no issues. You can use hondapartsunlimited to check it out, you would be amazed at how much you can find hardware wise by looking at different cars and categories.
However that being said, you could just stop in at some autoparts stores or hardware stores and see what they have. If the head is 10mm great, if its 11mm then don't buy it or hit up a salvage yard and just pull some hardware off a car, I have three big coffee cans full of oem hardware. lol
KiNGDEE206
10-27-2018 05:02 PM
AnonymousHatch
06-12-2018 08:56 PM
AnonymousHatch
06-10-2018 01:35 AM
