Fuel pump primes after 5-10 minutes of waiting
Hello people,
Heres the situation. Car: 93 Honda Civic Motor: Stock LS on boost. ECU: Chipped P75 ecu with Moates Demon RTP After turning the key to the on position the check engine light comes on and stays on for about 5 minutes and then turns off. When the MIL light turns off finally my fuel pump starts priming. I swapped ecus with a stock non-chipped ecu and everything works fine. So I know the problem resides in the chipped ecu. Then I removed the J1 jumper from the chipped ecu and tried again and the problem still persisted. I read somewhere that the C14 capacitor is problematic and tends give out. So I tried swapping that out with one I got from another ecu. Problem still persisted. I really would like to fix this ecu instead of socketing and chipping another ecu. What other troubleshooting could I do on my chipped ecu and do you have any idea what the proble could be. Thank you |
Re: Fuel pump primes after 5-10 minutes of waiting
bump
bump
bump
I've seen that problem before, I can't say what happened internally with the ecu but it was permanently resolved by completely changing the ecu.
It is a problem with the ecu. Pretty easy fix pm if your want to resolve the issue,
-Justin Advanced igntion |
Originally Posted by bgdriver
(Post 48993093)
I have finally figure out the problem.
It was the dang q10 transistor in the ecu. http://i37.photobucket.com/albums/e5...pseac0a33a.jpg bump Edit: I thought I fixed this problem but the problem still continues |
