Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   Fuel injectors are not spraying fuel (https://honda-tech.com/forums/tech-misc-15/fuel-injectors-not-spraying-fuel-526953/)
Sinner Jun 5, 2003 09:28 PM
I just did a motor swap and it motor was running ok, but when I hit the gas it would bog. Now I cant get it to start. I'm getting spark, but no fuel. we traced it down to the injectors. we pulled them off the IM, but left them hooked up to the fuel rail. I tried cranking it and I assume it should have sprayed fuel. Then I tried swaping out injectors. Still no fuel. Is there any fuse that would cause this? Anyone have any idea why the fuel injectors are not spraying?
Nick
mmuller Jun 5, 2003 11:34 PM
Re: Fuel injectors are not spraying fuel (Sinner)
is your fuel pump working?if it is then it could be your main relay
Sinner Jun 5, 2003 11:35 PM
yea the fuel is getting to the fuel rail. I took of the fpr and it sprayed fuel everywhere when I tried to crank it.
I took a multimeter to it and it gives me 12v with the key turned and about 10v when cranking. I guess its a pulse thing. Anyone got any ideas?
Nick
Modified by Sinner at 8:48 AM 6/6/2003
Sinner Jun 6, 2003 03:00 AM
bump, its the pulse to the injectors thats not working I guess. I hooked up the injectors and turned it on while I cranked and it shot fuel everywhere. What would keep the injectors signal from sending?
Sinner Jun 6, 2003 01:37 PM
bump
Sinner Jun 6, 2003 04:32 PM
help help me :-)
Flexmyrex Jun 7, 2003 05:16 PM
Re: (Sinner)
what engine and what car is it
was it plug and play or did you have rewire shit
b16supertuner Jun 7, 2003 07:01 PM
Re: (flexmyREX)
try swapping ECU's. i fried mine once. injector drivers went bad
Sinner Jun 8, 2003 02:51 PM
the problem was the cam gear's key broke... what ar the odds? I'm just posting incase it happens to someone else.
Nick
Ryan C Jun 8, 2003 03:03 PM
Re: (Sinner)
wow thats weird
